3D belt printing by iFactory3D
Automated additive manufacturing for
▫Serial production
▫Continuous objects
▫Complex geometries without support structures
PETG filament spool 1kg
24,99
Delivery time: 7 Days
SKU: N/A Category:
Description
The PETG filament spool of 1kg weight with its special product properties is especially suitable for the 3D belt printing technology developed by us.
Therefore, we recommend operating our 3D belt printers with the premium PETG by iFactory3D.
Product Features of PETG Filament Spool
The filament’s high transparency and temperature resistance combined with its low viscosity allow it to be used in many applications. Especially since PETG has one of the preferred properties for 3D printing of water and chemical resistance, as it is oil-based.
PETG as a base material has particularly wide compatibility with other materials, for example, admixtures of metal particles in the filament are not a problem, with a few adjustments and the right choice of the nozzle to use. Our recommended nozzle, its application areas, and specifications can be found on our product page for the original iFactory3D Custom Volcano Nozzle.
The filament spool in the 3D printer
iFactory3D PETG works and harmonizes perfectly with all common 1.75mm 3D FDM printers. We guarantee this through the manufacturing accuracy and the low diameter tolerance of +/- 0.02mm.
The optimized print quality and the resulting adherence to the high-quality standard of our, in distance and axis adjustable, nozzle design leads to the excellent layer adhesion typical for us. Of course, you will achieve the best results with our iFactory3D filament, whose special feature is a high degree of purity with only low shrinkage.
Manufacturing with the PETG Filament Spool
Our filament standard is characterized not only by its special material toughness. Our filament’s propensity for stability, coupled with the heated filament’s propensity for bonding, creates a special unity in the construction of your printed product.
The easy-to-process iFactory3D PETG filament works with our belt printers free of both clogging and bubbles.
For shipping, each individual filament roll that has been fully dried for 24 hours is vacuum sealed with desiccant in a nylon bag. This ensures that each of our filament rolls always arrives at your door ready to print and remains dry and free of contaminants or residue until the seal is broken.
Additional information
Color
Black, Orange
Material
Polyethylene terephthalate (PETG)
Item Weight
1.0 kilogram (2.2 pounds)
Diameter
1.75 millimeter
Designation
1.75 PETG Filament
Manufactured
in the Netherlands
Product Features
Dimensional accuracy and consistency:
1kg spool (2.2lbs): 1.75mm diameter, dimensional accuracy: +/- 0.02mm
Recommended PETG filament extrusion/nozzle temperature: 230 – 250℃.
Recommended bed temperature: 80℃
Compatibility: all popular 1.75mm 3D FDM and belt printers
Manufacturing accuracy and diameter tolerance: from +/- 0.02mm
Dimensions
  • Coil diameter is 200mm (8″)
  • Coil hub hole diameter is 52mm (2.20″)
  • Spool width is 75mm (2.5″)
Product Specifications
Material: polyethylene terephthalate (PETG)
Brand name: iFactory3D
Item weight: 1kg (2.20 pounds)
Outer diameter: 1.75mm
Item name: 1.75 PETG Filament
Made: in the Netherlands
Reviews
There are no reviews yet.
Only logged in customers who have purchased this product may leave a review.
You may also like…
