Tech-specs
Dimensions
Physical dimensions
710(l); 640(w) – 540(w) without spoolholder;
500(h) [mm]
Power input
110V/220V AC 50/60Hz
Weight
18 kg
Belt properties
Durable polymer belt optimized for 3D-Printing
Parts fall off automatically
Working as z-Axis, enables infinite
printing in size and number of objects
Operation
parameters
Print principle
Fused deposition modeling
Print speed
20-100 mm/s
Print quality
0.1-0.3 mm depends on nozzle and settings
Moving speed
<200 mm/s
Max nozzle temp
260°
Nozzle heat up time
<2 minutes
Filament
PLA,PETG, PC TPU ASA NYLON ABS…
Compatible filament diameter
1.75 mm
Operating sound
<70 dBA
Build plate (heat up)
20 ->100 °C in~5min
Monitoring
Raspberry Pi and HD Camera
Printer properties
Machine style
Belt printer 45°
Belt
Durable polymer belt optimized for 3D-Printing; parts fall off automatically; belt working as z-Axis, enables infinite printing in size and number of objects
Print volume (max)
Infinite(l) 290(w) 180(h) [mm]
Feeder type
Titan bowden extuder
Display
3.5″ 480×320 pixel touch screen
Nozzle diameter
0.4 mm exchangeable
Ecosystem
Slicer software
Cura ifactory3D
Printing software
Octoprint ifactory3D and Marlin ifactory3D
Supported OS
OSX, Windows, and Linux
Plugin integration
SolidWorks, Siemens NX, Autodesk Inventor
File transfer
SD-card; Wi-Fi (integrated raspberry pi 3A+
running octoprint); USB-cable
Nozzle heat up time
<2 minutes
Service
and support
Quality and Calibration Check
Via phone or video call wit one of our engineers
Online training
Lead by our engineers
Warranty period
1 year
Expert support
Dedicated technical support via email, phone is
available to you in English, German, Italian,
Russian
Downloads
